Nexus 7K SNMP V3 User
Answered Question
Sep 6th, 2009
Anyone now how to setup a snmp v3 user? Trying to use Solarwinds products and never can authenticate. Tried several ways. Would be great is someone uses Nexus and Solarwinds out there.
Correct Answer by Collin Clark about 7 years 1 month ago
I looked at the Nexus config guide for SNMPv3 and looks just like IOS. Check the link below, usually there is a mis-config in NCM.
Hope it helps.
Correct Answer by Lucien Avramov about 7 years 1 month ago
What version of NEX-OS do you have?
Overall Rating: 5 (2 ratings)
molinek Wed, 09/09/2009 - 11:24
Thanks for the link but NX0S doesn't have that view command. I'm going to try solarwinds support and see if they have anyting.
Roman Oseledko Sun, 08/05/2012 - 20:20
Take a look the SNMP privacy(encryption) settings. They have to be enabled globally.
I believe that by default, it's Auth only, not AuthPriv.
But also be careful, because NXOS creates a AAA user when you create an SNMPv3 user.
