Can't use community string indexing to get the dot1dTpFdbTable from 2900
Answered Question
Sep 7th, 2009
Hi everyone,
I have a Catalyst 2924 switch, configured with 3 VLANs, I can telnet to that switch and see the mac-address-table by issuing the following command:
Switch#sh mac-address-table
Dynamic Address Count: 5
Secure Address Count: 0
Static Address (User-defined) Count: 0
System Self Address Count: 47
Total MAC addresses: 52
Maximum MAC addresses: 8192
Non-static Address Table:
Destination Address Address Type VLAN Destination Port
0030.1890.1000 Dynamic 2 FastEthernet0/14
00d0.0648.f41d Dynamic 1 FastEthernet0/2
00d0.0648.f41d Dynamic 2 FastEthernet0/2
00d0.0648.f41d Dynamic 3 FastEthernet0/2
00e0.4c38.2d32 Dynamic 3 FastEthernet0/23
Switch#
Then on a Linux machine with net-snmp installed, I tried to get that mac-address-table with the following SNMP command:
[[email protected] ~]# snmptable -m /usr/share/snmp/mibs/Bridge.mib -c public -v2c 172.16.6.2 .1.3.6.1.2.1.17.4.3
SNMP table: BRIDGE-MIB::dot1dTpFdbTable
dot1dTpFdbAddress dot1dTpFdbPort dot1dTpFdbStatus
0:1:42:9:8a:40 40 self
0:1:42:9:8a:41 40 self
0:1:42:9:8a:56 40 self
0:1:42:9:8a:57 40 self
0:1:42:9:8a:58 40 self
0:d0:6:48:f4:1d 14 learned
ff:ff:ff:ff:ff:ff 0 mgmt
As you can see, it only displays the mac-address-table under VLAN1, not the whole mac-address-table, it's said that you have to use community string indexing to get the mac-address-table under each VLAN, but I tried and failed, as indicated by the following output:
[[email protected] ~]# snmptable -m /usr/share/snmp/mibs/Bridge.mib -c [email protected] -v2c 172.16.6.2 .1.3.6.1.2.1.17.4.3
Timeout: No Response from 172.16.6.2
You have new mail in /var/spool/mail/root
[[email protected] ~]# snmptable -m /usr/share/snmp/mibs/Bridge.mib -c [email protected] -v1 172.16.6.2 .1.3.6.1.2.1.17.4.3
The version of our Catalyst 2924 is:
Switch>sh version
IOS (tm) C2900XL Software (C2900XL-H2S-M), Version 12.0(5.1)XP, MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Fri 10-Dec-99 10:57 by cchang
Image text-base: 0x00003000, data-base: 0x002BA814
ROM: Bootstrap program is C2900XL boot loader
I tried community string indexing on another Catalyst 4000 L3 switch, and successfully got the mac-address-table of each VLAN, so why can't I get it on the Catalyst 2924 switch? Doesn't Catalyst 2924 switch (or the installed IOS) support community string indexing, or I didn't configure it properly? And is there any other way that I can get the whole mac-address-table on a switch with SNMP commnads?
Correct Answer by Joe Clarke about 7 years 9 months ago
This is known bug CSCdp45404. It is fixed in 12.0(5)XU and higher code. Community string indexing of the dot1dTpFdbTable is the only way to poll the MAC/CAM table with SNMP.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 09/07/2009 - 10:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
xwy5201314 Mon, 09/07/2009 - 23:01
Bravo! jclarke, thanks a lot for your reply, I have resolved the problem after upgrading the IOS of the Catalyst 2900 to :
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:27 by antonino
