Configure 2811 to block access to specific websites
femi.agboade
I have been trying to block access to specific websites on a client's 2811 running C2800NM-ADVENTERPRISEK9-M, Version 12.4(24)T.
I initially tried using ACL but the sites just keeps coming up. I followed instructions on this link http://articles.techrepublic.com.com/5100-10878_11-6115879.html, created the ACL, searched as much as i could the IPs linked to the domains I want to block, and then applied the ACL in the outbound direction on the WAN interface, but still no luck.
I was trying to use the SDM to configure the firewall, but i ended up blocking HTTP access to all websites :-(
Any advice will be much appreciated.
Femi
5 Replies 5
Richardsma
Post a copy of the ACL so others can see how you've configured it, substitute IP's if necessary.
Please see attached the config for the ACL I have on the router...
Femi
femi.agboade
I have been able to successfully block the websites, only after upgrading my IOS though. See below the commands used, note that you would need an AdvSec IOS on the router to be able to do this:
You can use the URL Filter functions
\\ set the url filter to a bogus websense IP address
ip urlfilter server vendor websense 192.168.15.15
\\-- set filter to bypass vendor server if it can't be reached (it can't)
ip urlfilter allow-mode on
\\-- setup a BLACKLIST that gets blocked before ever sending to vendor server
ip inspect name BLACKLIST http urlfilter
ip urlfilter exclusive-domain deny .facebook.com
ip urlfilter exclusive-domain deny .myspace.com
ip urlfilter exclusive-domain deny .youtube.com
\\-- apply filter to LAN interface
interface Fast 0/0
ip inspect BLACKLIST in
Femi
Joseph Adekoya
hi,
can i just ask why you want to use a router for http content filtering? dont you have mcaffe or ISA or pix with websense?
Hi Adekoya,
Thank you for our comments. However, if I had any of the appliances/software that you have mentioned, I would have used it dont you think???
Before ISA, PIX or McAfee, there was plain old Cisco IOS CLI and it worked pretty well...
Femi
