09-07-2009 05:02 AM - edited 03-15-2019 07:40 PM
hi
i have one 7961 phone with 7914 module.i need to monitor the status of 10 lines from module and need to transfer call if they are not busy.if i configure their line in this module,i will be able to see their call.i dont want this.i just j=need to know whether they are busy on phone or not..
asny option form phone other than attendant console.
09-08-2009 11:09 PM
Use them as Speed Dial/BLF
09-29-2009 10:18 PM
hi
i tried to configure the as given below.
i created one new phone button template with 14 lines in SPEEDDIAL/BLF lines.
the i aplied this template to receptionists phone.
then i added 14 lines to this sppeddial/BLF lines .
but cant see any change in recepionists phione.restarted phone.but still same.when there is call in any of these lines or any of those 14 lines are off hook,no status change on receprionists phone 7914 module.
pls help
so i need to chnage something else.
i am using CCM 5.1.
09-30-2009 06:27 AM
Check the SUBSCRIBE CSS is correctly configured to monitor the lines
java
if this helps, please rate
