Second call in the mode of peer to peer
Alberto Montilla Tue, 09/08/2009 - 09:59
  • Cisco Employee,
Dear Sir;
This has to do with the ports used for SIP for each line.
Line 1 is 5060
Line 2 is 5061
On the peer device you need to set the proxy to be : (port is included only if different from 5060).
It seems that other end is trying to call to the 5060 port, and local device is saying "Not Found". Try setting :5061 for the second line (on the peer device).
Alberto
Hello, Alberto
Thank you very much for addressing this issue, but I will say that this decision is grossly hardware, if we take for example cisco 827 there is no need to specify which port the call comes, it automatically determines which port will be used.
And if we assume that one room for 2 lines, can we not creating a second dialpeer on cisco, as some do. Just like any other device that works.
dial-peer voice 3808102 voip
  destination-pattern 3808102
  session protocol sipv2
  session target ipv4: 91.190.82.10
  codec g726r32 bytes 40
  fax-relay ecm disable
  fax nsf 000000
  fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
  no vad
Max
