500 Internal Server Error
Sep 7th, 2009
I am trying to get a UC520 to receive incoming calls with an ITSP.
Outbound works fine.
Per the carrier he states a 500 Internal Server Error.  I have upload his info.
Per other posts, I have read about fixing access-list 2 and the ip address that the calls are coming from.
I have addedd the two extra ip's and still no inbound calls.
Any suggestions.  I have upload the info from the carrier.
Any other thoughts.
Maulik Shah Mon, 09/07/2009 - 21:11
Since I do not have the config - do you have the inbound DID (14122350198) mapped to an internal extension. Make sure you map the exact DID as it maybe you mapped the 10 digits but your ITSP is sending 1 + 10 digits based on the debug sent. That maybe the issue.
7bridgesol Wed, 09/09/2009 - 13:31
yes, now the carrier is telling me this.
Your Cisco device is registering multiple times from DIFFERENT ports.  This is causing failures on routing because calls are often being sent to the older registration where the port indicated is no longer open.
Please have them help you configure your PBX so that ONLY port 5060 is used on the external interface of your network.  This will prevent multiple registrations from the same IP using the same username and will allow your inbound calls to work consistently.
I did remove some usernames for secuirty purposes.
Maulik Shah Wed, 09/09/2009 - 17:43
I am not sure I follow the SP reasoning but sure - you can force the UC500 to originate all SIP requests from UDP 5060:
sip-ua
  connection-reuse
Section 4.4.12 on doc below shows you how
https://supportforums.cisco.com/docs/DOC-9562
I looked at your config and seems like everything is setup ok for an inbound call. Can you gather "deb voip ccapi inout" & deb ccsip messages" from the UC500 for one failed call?
7bridgesol Thu, 09/10/2009 - 08:00
well inbound calls are working but ITSP still states this.
At present, there are two active registrations from each of your DIDs.
sip:[email protected]:50570
sip:[email protected]:5060
This WILL cause problems with inbound number routing.
What gives here.
Also, per that config, 14122350199 is not working.  Any thoughts on that?  Its plugged into fxs 0/0/0
Maulik Shah Thu, 09/10/2009 - 10:52
Do not see your config anymore - can you PM that to me.
Not sure why the SP sees 2 registrations for the same number - see if you can remove the registrar server on the UC500 and add back:
sip-ua
  no registrar
  registrar
May also want to ensure SP clears the cache on their registrar server if its storing old values.
On why calls to 0199 do not work - would have to look at the config again and see if there is a mapping for this DID to the FXS 0/0/0 extension
Maulik Shah Fri, 09/11/2009 - 14:58
I see the issue - there does not seem to be the right DID to extension dial peer created. Did you configure the analog port DID via CCA or did you use CLI? If this is CCA - let me know the CCA version as this maybe something we need to fix with CCA.
FYI - as a workaround you can add the below:
dial-peer voice 11006 voip
description ** FXS from SIP Trunk **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number 14122350199
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
Let me know if that fixes the issue.
7bridgesol Mon, 09/14/2009 - 07:49
dpone faxes are coming thru.  thank you.
I followed the steps in the sip config giude. but never verified the dial-peer.
will make a note of that.
7bridgesol Wed, 09/23/2009 - 12:20
two things are going on.  I can call the 4122350199 to have the fax machine to ring, but actually can't receive a fax. Also, can't send out faxes.  I can pickup the receiver and makes calls.
Also have a secondary number forwarded to an internal ext.  The SP states this.
Your system is rejecting inbound call attempts:
U 2009/09/23 18:22:48.888933 72.95.154.133:5060 -> 66.23.129.253:5060
  SIP/2.0 500 Internal Server Error..Via: SIP/2.0/UDP 66.23.129.253:5060;bran
  ch=z9hG4bKc445.42f4b291.0,SIP/2.0/UDP 208.94.159.10:5060;branch=z9hG4bK-14e
  031-4aba6778-46229ff1-43e3bc19..From: <sip:[email protected]:5060>; - I deleted my number here
  tag=a9f5ed0-13c4-4aba6778-46229ff1-7f0ccf60..To:
  .253:5060>;tag=1F73ACFC-17E2..Date: Wed, 23 Sep 2009 19:22:41 GMT..Call-ID:
   [email protected]59.10..Se
  rver: Cisco-SIPGateway/IOS-12.x..CSeq: 1 INVITE..Allow-Events: telephone-ev
  ent..Reason: Q.850;cause=63..Content-Length: 0....
Any thoughts.  I have uploaded my config again.  I did remove usernames
Steven Smith Wed, 09/23/2009 - 13:19
Can you get a SIP trace from the UC500 when you do this?  Are you trying to use T38 faxing?
7bridgesol Fri, 09/25/2009 - 06:54
okay, I as of right now can get the faxes in.  The problem is when I send a fax the other side hears their machine ring, picks up, but never allows me to send the message.
Any ideas?
Maulik Shah Fri, 09/25/2009 - 11:29
Is the debugfax.txt indicative of the error you mention in the last post? Assume not as that shows a busy coming back.
Do you have a debug on the below? I would say we need to look at the signaling to see if T.38 even gets negotiated.
7bridgesol Fri, 09/25/2009 - 12:13
no.  I am waiting for someone to get back to the other site and will post a new debug on an outbound fax.
Also, any thoughts on this inbound call to 724-216-6522.  This is what I got back from the service provider.  The other DID we have works just fine.
  031-4aba6778-46229ff1-43e3bc19..From: <sip:[email protected]:5060>; - I removed my cel
Maulik Shah Mon, 09/28/2009 - 22:17
Trying to keep track of all the issues here - for this issue - coupleof questions:
1. Do you need to register this DID with the SP? If so check to see if this is in the list of registered DIDs (show sip register status)
2. If the above is ok, then make sure you have an inbound dial-peer for this DID via CCA inbound dial plan - make sure you add the exact DID including the 1 if that is what the SP sends you. Sample CLI would be as below:
dial-peer voice 11008 voip
description ** DID from SIP Trunk **
voice-class codec 1
incoming called-number 1724xxxxxxx
dtmf-relay rtp-nte
no vad
7bridgesol Tue, 09/29/2009 - 13:28
per my last response I added the two other IP's to my access-list and all good.
The problem I have is the number I am using ofr inbound 7242166522 points to ext 203 with cfwdall to someone's cell phone out of the office.
When I test they say the call breaks up.  Is this a result of what I see referred to as a hairpin.
If so I can I fix the quality of the call.
Maulik Shah Wed, 09/30/2009 - 11:06
Glad to know the fax issue was sorted out and also the inbound calls.
For the QoS issue - areas to check:
- if you use CCA 2.1 - you can do the below to enable QoS on the UC500 outbound
Configure > Routing > Internet Connection, select the interface and click Modify, then click on Traffic Shaping tab to configure QoS settings for the WAN connection. On the Traffic Shaping tab, check Enable Traffic Shaping, enter the appropriate upstream bandwidth for your WAN connection in Kbps and reserve the appropriate bandwidth for SIP calls over the WAN.
- the rest depends on your internet connection - make sure you have appropriate upstream bandwidth for SIP Trunk calls and data. If G711 is your voice codec, its about 80Kbps per call so engineer your bandwidth around that.
7bridgesol Wed, 10/07/2009 - 12:59
thanks for all your help.  We actually went to are carrier upgrade our service for more upload speed.
As of yesterday all cfdall calls are clear as a whistle.
Thanks again.
7bridgesol Tue, 09/29/2009 - 13:18
I added your config and this is what th Sp has stated right now.
U 2009/09/29 19:45:24.823222 192.168.1.50:5060 -> 96.236.161.14:5060
  INVITE sip:[email protected]:5060 SIP/2.0..Record-Route:
  [email protected]:5060;nat=yes;ftag=a9f5ed0-13c4-4ac263d5-6553b33a-2c638
  3a7;lr=on>..From: <sip:[email protected]:5060>;tag=a9f5ed0-13c4-4ac
  263d5-6553b33a-2c6383a7..To: <sip:[email protected]:5060>..Call-ID:
   [email protected]9.10..CSe
  q: 1 INVITE..Via: SIP/2.0/UDP 66.23.129.253:5060;branch=z9hG4bKa7e2.c6fbd71
  .0..Via: SIP/2.0/UDP 208.94.159.10:5060;branch=z9hG4bK-1653e7-4ac263d5-6553
  b33a-72a62054..Max-Forwards: 16..Remote-Party-ID:
  cs.com:5060>;id-type=subscriber;privacy=off;screen=no..Contact: @208.94.159.10:5060;transport=udp>..Min-SE: 900..Session-Expires: 1800
  ..Content-Type: application/sdp..Content-Length: 217....v=0..o=Covergence_U
  AS 0 1 IN IP4 208.94.159.10..s=SIP Media Capabilities..c=IN IP4 208.94.159.
  10..t=0 0..m=audio 20334 RTP/AVP 0 18 101..a=rtpmap:101 telephone-event/800
  0..a=rtpmap:0 pcmu/8000..a=rtpmap:18 g729/8000..
And here is your response:
U 2009/09/29 19:45:24.910264 96.236.161.14:5060 -> 192.168.1.50:5060
  ch=z9hG4bKa7e2.c6fbd71.0,SIP/2.0/UDP 208.94.159.10:5060;branch=z9hG4bK-1653
  e7-4ac263d5-6553b33a-72a62054..From: <sip:[email protected]:5060>;t
  ag=a9f5ed0-13c4-4ac263d5-6553b33a-2c6383a7..To:
  253:5060>;tag=3EA51D54-3C3..Date: Tue, 29 Sep 2009 19:45:02 GMT..Call-ID: C
  [email protected].10..Serve
  r: Cisco-SIPGateway/IOS-12.x..CSeq: 1 INVITE..Allow-Events: telephone-event
I have uploaded a new config for you.
Maulik Shah Mon, 09/28/2009 - 22:42
From the logs I see the below:
UC500 -------------> FAR END FAX
Sep 25 20:27:55.880: Sent: INVITE
Sep 25 20:27:56.172: Received: SIP/2.0 100 trying -- your call is important to us
Sep 25 20:27:59.316: Received: SIP/2.0 183 Session Progress
Sep 25 20:28:19.704: Received: SIP/2.0 200 OK  <<<<<<<<<<<<<<<<<<<<<<< FAX Answered
<8 seconds later call is disconnected by UC500>
Sep 25 20:28:27.724: Sent: BYE
However see no other message for the remote site upspeeding T.38 so I assume this is not T.38. Can you call that number from an IP phone - do you hear the fax tones? Do all outbound faxes fail? See nothing wrong on the UC500 as the call is setup as G.711 - does your SP say what fax method they use?
7bridgesol Tue, 09/29/2009 - 13:14
faxes are good.  i tried two different companies and they got the,  Must have been just that particular fax
