The TCL Scripts for T.37 Store and Forward Fax not load in 12.4(15)T7
Sep 7th, 2009
I'm using a Cisco 3825 with Cisco Internetwork Operating System. Cisco IOS (tm) C3825 C3825-ADVIPSERVICESK9-M, The System version is 12.4(15)T7 / CME 4.1(0) and I try to configure a "T.37 Store and Forward Fax" but when I download the latest version of tcl script (app-faxmail-onramp.2.0.1.3.zip and app-faxmail-offramp.2.0.1.1.zip) and I put it on my router cannot do anything!!!.
And when I check how to solve this problem I found when I put in the CLI the command: "sh call application voice onramp_kywi" (onramp_kywi calls the script app-faxmail-onramp.2.0.1.3.zip) only have the next response:
Script Name : onramp_kywi
URL : flash:app-faxmail-onramp.2.0.1.2.tcl
Type : Service
State: Not Loaded
Life : Configured
Exec Instances: 0
Script Code Begin:
The same thing ocurs with the offramp script.
The most "worrying" part is when the command says about the script "State: Not Loaded"
Do you have any fix/solution to this problem???...I need urgent help!!.
Thanks!!
