Cannot associate an ephone-dn with a FXO port
Sep 7th, 2009
To associate an ephone-dn with a foreign exchange office (FXO) port, I use the trunk command in ephone-dn configuration mode...but when I finish the config and press the button in my phone...anything happens..What am I doing wrong?
this is the config:
BEGIN=========================================
!Private Lines
!Direct 1
conf t
voice-port 0/1/0
connection plar opx 2220970
exit
!Dial peer to take Private Line 1
dial-peer voice 280 pots
destination-pattern 7100
port 0/1/0
exit
!Direct 2
voice-port 0/1/1
connection plar opx 2220973
exit
!Dial peer to take Private Line 2
dial-peer voice 281 pots
destination-pattern 7101
port 0/1/1
!!Ephone-dn to assign the private lines, the sentence "trunk" take the dial peer to send the calls to port 0/1/0
!Linea 1
ephone-dn 110
number 2220970
name "Linea Privada 1"
!invoque the destination of connection in FXO private line 1
trunk 280
!Linea 2
ephone-dn 111
number 2220973
name "Linea Privada 2"
!invoque the destination of connection in FXO private line 2
trunk 281
!Asigne the ephone-dn to the buttons, in ephone 6 the private line only in silent mode
ephone 5
button 1:5 2:251 5:110 6:111
ephone 6
button 1:6 2:250 5s110 6s111
END========================================
I need some help with this issue..
Thanks!!
juan.astudillo Fri, 09/11/2009 - 08:52
Yes, I used this guide to associate the ephone, if you see the script that I published..have the same structure as examples and use the "trunk" command but When I try to take the line only have a busy tone. It is not a trunk problem because when I test the configuation I receive the incoming calls normally. The problem is I cannot use the line to make outgoing calls.
I think I associated wrong the dial-peer with the command "trunk". While I programmed I saw that the "trunk" command says nothing of its parameters that can only be of type "WORD". This is not very specific so I have doubts.
Thanks for your help!!
