Routing Help - Urgent
Answered Question
Sep 7th, 2009
Need Urgent help on specific routing requirements
In Our Scenario Site_A is connected to Site_B via IPSEC GRE Tunnel running OSPF as routing protocol.
Site_A host all applications for Site_B.
We already have inplace another point-2-point link between Site_A to Site_B and
have specific requirement.
POS_Server only from Site_A should send traffic on this P-2-P link to Site_B.
Any traffic initiated from Site_B to POS_Server on Site_A should be via P-2-P link.
All other traffic should pass IPSEC-Gre_Tunnel.
Kindly Help.
Correct Answer by Edison Ortiz about 7 years 9 months ago
You will place the 'ip policy' under Vlan 10 and it will only match on the server ip address, remaining traffic will remain as before.
__
Edison.
Overall Rating: 5 (1 ratings)
Mohamed Sobair Mon, 09/07/2009 - 11:02
  • Gold, 750 points or more
I assumed default traffic is passing IPsec GRE tunnel
For the POS_Server you will need to have policy based routing.
Likewise , for the traffic initiated from site_B to POS_Server you will also need to have policy based routing.
Mohamed
Jon Marshall Mon, 09/07/2009 - 11:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you need to send certain traffic one way based on the source IP address then you need to use PBR (Policy Based Routing). See this link for configuration details -
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ip_prot_indep_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056703
Jon
Edison Ortiz Mon, 09/07/2009 - 11:07
  • Hall of Fame,
    Founding Member
You will need Policy-Based Routing (PBR) on both routers as you will modify the routing based on the source.
On the router at Site_A
access-list 101 permit ip [server_ip] [site_b subnet]
route-map server_pbr
match address 101
set ip next-hop [p-2-p link]
interface fx/x
description LAN facing interface
ip policy route-map server_pbr
On the router at Site_B
access-list 101 permit ip [site_b subnet] [server_ip]
match address 101
interface fx/x
HTH,
__
Edison.
Amin Shaikh Mon, 09/07/2009 - 12:18
Thanks to all for the input.
This is the way my backbone router is connected to POS_Server and VPN_Router.
I didnt get where should I apply the IP policy route-map command.
Vlan=192
BackBone_Router : 192.168.10.1/30
VPN_Router : 192.168.10.2/30
Interface gi3/12
Description connected to VPN_router
switchport access VLAN 192
Vlan=10
BackBone_Router : 10.10.10.254/24
POS_Server : 10.10.10.75/24
Interface 2/7
Description Connected to POS_Server
Switchport access vlan 10
On VLAN 10 there more server's which needs to be accessed from Site_B and the traffic needs to flow via IPSEC_GRE_Tunnel
Hopefully this config will not impact traffic for other server.
Correct Answer
Edison Ortiz Mon, 09/07/2009 - 15:59
  • Hall of Fame,
    Founding Member
__
Edison.
