Unable to change default Numbering Plan on CUCM 7.0.2
zahid.hassan
Dear All,
I am trying to change the default numbering plan from NANP to UKNP.
I have installed the locale file "cm-locale-en_GB-7.0.1.3000-1.cop.sgn"
twice from the below location from CCO and rebooted the server.
Voice and Unified Communications >
Cisco Unified Communications Manager Version 7.0 > Unified Communications Manager/CallManager Locale Installer>
7.(1.3000-1)
I still can not pick anything other then NANP under Route Pattern Configuration.
Is anyone aware of any known issues with this ?
Also, this is the NFR edition of the CUCM server. So, not sure if this is anything to do with it.
Many thanks in advance.
Zahid
Jaime Valencia
You installed a locale (as the name clearly explains) NOT a dial plan.
Download the GB dial plan and install it, there is a section called Cisco International Dial Plan in downloads.
java
if this helps, please rate
java
Jaime Valencia
java
java
lafirzaman
you need to doanload dp-ffrxxxx.GB.cop.sgn from international dial plan and install it mate. what you've done is local this is GB english inteface for GUI and phone.
Many thanks for this. Someone already pointed out mistake earlier.
Regards, Zahid
