CME Ephone PLAR
Sep 7th, 2009
I have an ATA using SCCP connected to a doorphone on CME7. I'd like to program a PLAR to ring a huntgroup when the doorphone goes offhook but the only references that I can find to PLAR in the CME manual are for FXO ports. Does anyone know how to configure an ephone for PLAR?
Overall Rating: 5 (1 ratings)
cnscisco Sat, 07/10/2010 - 20:49
Kenneth,
Thank you very much. Your reference doc did the trick. I also had an analog door phone hooked up to an ATA an spent a bit of time trying to get a PLAR defined for that port so that pressing the doorphone button would autodial an internal hunt group. Problem is that you cannot specify voice-port x/x/x for a SCCP ATA.
The solution as Kenneth suggested is to use the intercom feature....."It's so simple, even a caveman (like me..) can do it...". It's in the doc anyway.
ephone-dn  11
number 4235
label doorphone
name doorphone
intercom 4444
ephone  11
mac-address 1C58.F93E.1401
button  1:11
That's it. One minor issue is that I notice the phones in the hunt group ring once AFTER they hang up. I'll chase that one down another day, for now, I'm happy. Thanks again Ken.
BDB
