09-07-2009 09:24 PM - edited 03-15-2019 07:40 PM
Does CUCM 7.x run on 64-bit or 32-bit Linux?
Can it run on both? If so, which would be the more common in deployments: 32-bit or 64-bit?
Thank you!
David
Solved! Go to Solution.
09-07-2009 11:20 PM
I believe it's only 32bit version, as far as I remember you don't have any option to choose Linux version during installation.
Even when you look at MCS server for CUCM there is no information about 64bit parts.
09-08-2009 07:32 AM
Hi David,
I'm sure that is 32-bit Linux version. This linux version for CUCM is based on Red Hat Enterprise linux.
If you found this post helpful,please rate it.
09-07-2009 11:20 PM
09-08-2009 07:32 AM
Hi David,
09-08-2009 04:55 PM
Thank you very much folks, this answered my question.
