ip communicator licensing
Answered Question
Sep 7th, 2009
Hi to all,
i have a call manager 7 and i want to add ip communicator on the customer pc.
I have buyed the license for all the pc but i want know if i need to buy the software for every pc or if i can use only one software for every pc.
Thanks and best regards,
Carlo S.
Correct Answer by Jaime Valencia about 7 years 10 months ago
The SW is exactly the same for every machine, if you already have your licensing and DLUs use the same download.
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Tue, 09/08/2009 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    2011
java
