Ciscoworks report for switchport capacity
Sep 7th, 2009
Is there a report in Ciscoworks for switchport capacity?
I need to run the report for all my switches in a campus network. If i go to device centre i can run the "Switch Port Report - Switch Port Capacity" for a single switch. I need this exact report run for every switch that I have in ciscoworks
thanks
mattwilsonuk Mon, 09/07/2009 - 23:35
What version are you running, can you find the same report using
Resource Manager Essentials >
Reports >
Report Generator >
and select an Inventory report?
Matt
