CCM7.0(1) Transformation Pattern problem
Sep 8th, 2009
  • Cisco Designated VIP,
    2017 IP Telephony
Guys,
I am trying to use the call transformation pattern to change my ANI on my phones, but its not working. I have configured the ff:
1. Transform CSS and PT
2. Tranform pattern
3.Applied the xform css to the phones device pool
4. Check the "allow gateway to use device pool css" on the gateway.
Pls is there something else to od to make this work....Thanks
gogasca Tue, 09/08/2009 - 23:29
  • Green, 3000 points or more
Are you using EPMN (External phone mask number) what is your DN you are using and which is your Transformation Mask?
In Device are you using?
Use Device Pool Calling Party Transformation CSS option please let us know more details,
