Cannot sh run or ls
Fairly new to ACS. Our 4.2 has been working fine until about 2 weeks ago. I have an account as part of the admin group, that group is set to lvl15 priv. When I telnet into any of our routers or linux servers, we can log in, but once we issue a sh run on routers or ls on ix boxes the session freezes. It appears to be anything related to listing etc. I can get into exec mode on our routers, those that are not part of any aaa, same problem, can't sh run
Jatin Katyal Tue, 09/08/2009 - 04:13
As stated that when you execute "SH RUN" the session freezes. Does it shows the o/p after sometime or it gives any error message.
Also, do you have command authorization configured on router/ACS?
Please check the shared profile component >> shell command authorization set. Also check go to admin group and check the tacacs+ settings.
From one of your device in question, please send the output of the below listed command
"sh run | in aaa"
JK
Hi, JK,
I tried what you suggested, but no luck. The odd thing is the router I am telnet to is not AAA enabled,
Password:
golr_middelburg>en
Password:
golr_middelburg#sh run | in aaa
no aaa new-model
Building configuration...
and that is where is stays for a long time until it disconnects. I created a new account and put it in the default group, it did not make a difference. The new account also have lvl15 priv. However I can RDP fine to servers, it's just when you seem to pass output from telnet like ls or sh run...
Sincerely
Jagdeep Gambhir Tue, 09/08/2009 - 07:56
Do you have any policy map configured on the router, that can cause session to freeze.
~JG
