Unique ID's for Call Records
Sep 8th, 2009
Hi There all
If I wanted to query the records in IPCC database, is each record (contact) assigned a unique ID in the database and can this be used to return records from??
I am struggling to soft out this problem.
Thanks in advance
pmontsinger Tue, 09/08/2009 - 08:27
The composite of PeripheralCallKey and PerpipheralCallKeyDay identify a unique call. Do a search on Termination_Call_Detail for the ANI of the call you are interested in, find the two fields mentioned above and then do another query using them instead of ANI. That will show you all of the segments associated with that unique call.
