09-08-2009 03:24 AM - edited 03-15-2019 07:40 PM
Hi, Has anybody managed to get a CMM module to work for conferencing with UCM v7. I am looking at doing a major 4.1 - 7.0 upgrade and can only see a maximum of version CM 5.0 in the 'sccp ccm' command. The CMM is running the latest IOS available wscmm-ipvoice-mz.124-15.T9.bin.
Damian
09-08-2009 11:08 PM
CMM Module is compatible with CUCM 7.1.2. Though I couldn't find this documented anywhere. I took access to CUCM 7.1.2 and found an option to add "Communication Media Module".
Ive seen customer using 7.x and cmm succesfully as voice gw, xcoding, mtp and conferencing.
08-13-2010 05:49 AM
Hi, have you guys by any chance found an answer to this? I'm trying to implement the same thing. I've upgraded my CCM module to the latest IOS release 12.4-25c but when I configure the command "sccp ccm 10.2.101.11 identifier 1 version xx", the version stops at 4.1, it doesn't go up to 7.0+ Thanks & Cheers,
Jas
