ASDM 6.2.1 problem - fw image version number null
Sep 8th, 2009
I have just upgraded ASA5540 to code 8.2(1) and ASDM 6.2(1). But now, I can't start ASDM because of "Your firewall image has a version number null which is not supported by ASDM 6.2(1)" message. Any idea?
Thanx in advance
Radim
Kureli Sankar Tue, 09/08/2009 - 06:33
  • Cisco Employee,
I just tried it (8.2.1 and 6.2.1)and it works fine for local authentication.
Pls. issue a sh ver and make sure you are running 8.2.1
If you had a boot system statement in your config(sh run boot) it may still load the old code even though you uploaded the latest code onto flash.
Radim Jurica Tue, 09/08/2009 - 07:26
I use local auth too, I access through outside interface.
# sh ver
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
fw up 1 day 0 hours
failover cluster up 3 days 22 hours
Hardware: ASA5540, 1024 MB RAM, CPU Pentium 4 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0 : address is 0018.7317.b2a2, irq 9
1: Ext: GigabitEthernet0/1 : address is 0018.7317.b2a3, irq 9
2: Ext: GigabitEthernet0/2 : address is 0018.7317.b2a4, irq 9
3: Ext: GigabitEthernet0/3 : address is 0018.7317.b2a5, irq 9
4: Ext: Management0/0 : address is 0018.7317.b2a1, irq 11
5: Int: Internal-Data0/0 : address is 0000.0001.0002, irq 11
6: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 200
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
SSL VPN Peers : 2
Total VPN Peers : 5000
Shared License : Disabled
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions : 2
Total UC Proxy Sessions : 2
Botnet Traffic Filter : Disabled
This platform has an ASA 5540 VPN Premium license.
Serial Number:
Running Activation Key:
Configuration register is 0x1
Configuration last modified by enable_15 at 17:13:58.859 METDST Tue Sep 8 2009
Thanx, R
