Error on login....how do I fix this?
Sep 8th, 2009
So, I have a IDSM-2 module in a 6513 switch. When I try to login to the device I get the follow error:
login: PAM Failure, aborting: Critical error - immediate abort
This looks like a Linux error, at least Google searchs show that it happens in linux systems...which, I believe, the IDSM-2 is built upon.
So, how do I fix it?
Mike
rhermes Tue, 09/08/2009 - 09:18
  • Gold, 750 points or more
Your order of operations are:
1. Reload the IDSM-2 (from the host router, "hw-module module N reset")
2. Reload the IDSM from the maintenance pratition:
"hw-module module N reset cf:1" (to boot the maintenance partition)
and either upgrade (url of your file server holding a new image required) or restore.
