VPN Connectivity
darren.crofts
I have se-up a VPN connection to an 877, using Cisco VPN client. I am able to establishg a tunnel and can ping interface Vlan1 on the 877. There is a primary and seconday address on interface vlan 1 and the server that I need to RDP onto is on the secondary interface address. I am unable to ICMP to the server. Although from the router I can ICMP the server. I have tried many scenarios, currently the DHCP Pool for VPN clients is on the same subnet as the server.
Any ideas?
Darren
7 Replies 7
Collin Clark
Can you post the relevant crypto info from the router(s)?
Hi Colin,
There you go..
Current configuration : 5621 bytes
boot-start-marker
boot system flash c870-advsecurityk9-mz.124-15.T9.bin
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authentication login userauthen local
aaa authorization exec default local
aaa authorization network groupauthor local
aaa session-id common
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.30
ip dhcp excluded-address 172.16.1.65 172.16.1.94
ip dhcp excluded-address 172.16.1.97 172.16.1.126
ip dhcp excluded-address 172.16.1.129 172.16.1.158
ip dhcp excluded-address 172.16.1.161 172.16.1.190
ip dhcp excluded-address 172.16.1.193 172.16.1.222
ip dhcp excluded-address 172.16.1.225 172.16.1.254
ip dhcp pool Test
network 172.16.1.0 255.255.255.0
dns-server 172.16.1.1
default-router 172.16.1.1
lease 3
ip domain lookup source-interface Vlan1
ip domain name yourdomain.com
ip host test 192.168.1.150
ip name-server 62.24.128.18
ip name-server 62.24.128.17
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group remoteaccess
key cisco321
dns 172.16.1.1
pool remoteaccess
crypto ipsec transform-set remoteaccess esp-3des esp-md5-hmac
crypto dynamic-map dynmap 5
set transform-set remoteaccess
reverse-route
crypto map remoteaccess client authentication list userauthen
crypto map remoteaccess isakmp authorization list groupauthor
crypto map remoteaccess client configuration address respond
crypto map remoteaccess 10 ipsec-isakmp dynamic dynmap
archive
log config
hidekeys
interface ATM0
no ip address
ip nat outside
ip virtual-reassembly
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description test LAN
ip address 192.168.1.1 255.255.255.0 secondary
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Dialer0
ip address x.x.x. x.x.x.x
ip nat outside
encapsulation ppp
ip policy route-map VPN-Client
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname x.x.x.x
ppp chap password 0 x,x,x,
ip local pool remoteaccess 192.168.1.225 192.168.1.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip route 62.24.128.18 255.255.255.255 Dialer0
ip route 172.16.1.50 255.255.255.255 Dialer0
ip route 172.16.1.224 255.255.255.224 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip dns spoofing 172.16.1.1
ip nat inside source list 103 interface Dialer0 overload
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 23 permit any log
access-list 101 permit ip any any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 0.0.0.0 255.255.255.248 any
access-list 102 permit ip 172.16.1.0 0.0.0.255 any
access-list 103 permit ip 172.16.1.0 0.0.0.255 any
access-list 103 permit ip 192.168.1.0 0.0.0.255 any
access-list 104 permit ip 172.16.1.224 0.0.0.31 any
access-list 104 permit ip host 10.1.1.10 any
access-list 104 permit ip host 172.16.1.50 any
access-list 104 permit ip 192.168.1.224 0.0.0.31 any
dialer-list 1 protocol ip permit
no cdp run
route-map VPN-Client permit 10
match ip address 104
set interface Vlan1
I don't see your crypto ACL, but does it include the secondary IP subnets?
Hi Colin,
I have pasted all my config. I thought the router map would do the same thing as the crypto ACL as the interesting traffic.
Darren.
cool, I've never used a route map for it. Anyway, you're encrypting all traffic to the remote site correct? The tunnel is up and working except for the secondary subnets correct?
Hi Colin,
That's right. very weird problems.
Darren.
Darren-
I need a day or two to lab it up and test. If you need this quicker than that, you might want to re-post or open a TAC case.
