09-08-2009 06:20 AM - edited 07-03-2021 06:01 PM
Can anyone tell me how to bring this interface back up? It's a 1252 with 80211.n.
I started configuring it with CLI and then was using the web interface. I made a change on the web interface and it caused the AP to hang. I rebooted it and can access via Hyperterminal, but I cannot ping the IP address nor bring it up in the web interface any longer.
I tried the "No shut" command in the BVI1 interface.
09-08-2009 02:27 PM
Have you tried erasing the config?
09-09-2009 10:27 AM
What change did you make in the GUI when the AP hung?
You can always try to go in through the CLI issue a write erase command, which will erase the current config and you can then redo the config.
Alternately just try reconfiguring the BVI1 interface and verify all your other settings.
09-15-2009 12:47 AM
Hi Steve,
Check that the management VLAN's bridge group is 1 so it ties in with the BVI1, I vaquely recall this getting out of step on one of our APs that started misbehaving during reconfiguration.
Hope this is helpful
Scott
07-26-2012 11:30 PM
I had similar issue and had to put
int gi 0
bridge-group 1
for BVI 1 to come up .
BVI1 10.10.1.53 YES NVRAM down down
Ap2(config)#int gi 0
Ap2(config-if)#br
Ap2(config-if)#bridgeg
Ap2(config-if)#bridge-
Ap2(config-if)#bridge-group 1
Ap2(config-if)#
*Mar 12 17:36:38.374: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar 12 17:36:39.374: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
Ap2#sh i
*Mar 12 17:38:32.979: %SYS-5-CONFIG_I: Configured from console by consolep int brie
BVI1 10.10.1.53 YES NVRAM up up
Dot11Radio0 unassigned YES NVRAM administratively down down
Dot11Radio1 unassigned YES NVRAM administratively down down
GigabitEthernet0 unassigned YES NVRAM up up
