Inventory failure on some 6506
Answered Question
Sep 8th, 2009
I have LMS3.1 .
I have 4 Cat6506 which are failed in my inventory.
Althoug there 1 cat6506 wich is OK.
There is no difference between the one OK and the others.
All Cat 6506 have soft s72033-ipservicesk9_wan-mz.122-33.SXI1.bin.
I allreaddy updated lms with patch SharedInventoryCatSwitch.zip (4/22/09)
I tried to restart an inventory, and I also delete and reinstall the devices.
Have you got an idea ?
Include : the sh snmp-conf and sh ver of the 2 devices:
10.160.0.1 : OK
10.160.0.2 : NOK
Note that the snmp is version 3
Michel
Correct Answer by Joe Clarke about 7 years 7 months ago
This is indeed a timeout issue. The branch is the FLASH-MIB which is known to be a bit slow. Try increasing the RME SNMP timeout for these failing switches under RME > Devices > Device Management > RME Devices > Edit Attributes. Go with 10 seconds, and inventory should be successfully fetched.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 09/08/2009 - 08:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the IC_Server.log after performing an inventory collection job to one failing 6500. Why did you update SharedInventoryCatSwitch.zip? I assume it was for CSCsx58694.
mmisonne Wed, 09/09/2009 - 01:03
Here can you find the file.
Note that 10.160.0.1 ( The first 6506)is OK and the 4 other 6506 :10.160.0.2 /.3/.4/.5 fails with snmp timeout.
Allthoug the discovery is sucessfull for all the 5 x 6500 , and they have the same snmp config.
About the update "sharedInventoryCatSwitch.zip" , it is indead for the bug .
Michel.
Correct Answer
Joe Clarke Wed, 09/09/2009 - 09:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
mmisonne Thu, 09/10/2009 - 04:10
Hi Jim,
Indeed it works now.
Thanks a lot
Michel
