Copying ACS Module (ACE20) Context Configs
Sep 8th, 2009
Is there anyway to pull all of the context configures in one shot? Can I copy them from the Admin context or do I have to changeto each context and do a copy run?
dirttrackfvr Tue, 09/08/2009 - 15:36
I am trying to just begin the configuration process of the GSS, my SC knows about as much as me.. I sure could use some assistance! Thanks
cstockwe Tue, 09/08/2009 - 21:31
I just paste a set of commands from the admin context which manually copy the running configs to a tftp server...once each context is done it moves to the next.
It is a quick and nasty way of making sure all your contexts are backed up.
Like this:
ace01/admin# changeto context1
ace01/context1# copy running-config tftp://
ace01/admin# changeto context2
ace01/context2# copy running-config tftp://
ace01/admin# changeto context3
ace01/context3# copy running-config tftp://
...and so on for all the contexts you have.
jason.williams@... Wed, 09/09/2009 - 04:32
My problem with this is that it seems that only that admin context can reach my PC, and that's only over sftp. The other contexts are blocked by a firewall, that's why I was trying to find a way to copy the configs from the admin context.
Gilles Dufour Wed, 09/09/2009 - 04:53
Each context should have its own management access as they must be managed separately.
This is the idea behind virtualization...
So, fix the firewall and have a minimum config in order to access the context directly.
ACE does not have a mechanism to copy information from one context to the other for security reason.
