How manager phone numbers in large cluster
Sep 8th, 2009
I want to know in large CUCM clusters(10000+ phones) how to manager the user's phone numbers?Any product help this job?I'm rellay confused.
Overall Rating: 0 (1 ratings)
David Hailey Sat, 07/31/2010 - 00:16
I've managed a large cluster (about 15000 phones) so I may be able to help you out here.  What is it that you're looking to do and what is it that you find confusing?  If you can provide some more info, I'll be glad to try and help you out.
Chris Lee Thu, 01/27/2011 - 13:01
Did you ever get the help you needed for your large cluster of phones?
Just checking,
David Hailey Thu, 01/27/2011 - 18:55
If you want to use a provisioning tool to help manage this (likely the easiest route), then you can check out various offerings from 3rd-party vendors such as 2Ring's MACC, CUPM (Cisco Unified Provisioning Manager), and even vendors like Mitel have products that help with this.
Please rate helpful posts!
