Uninstalling Cisco CallManager 4.2
Answered Question
Sep 8th, 2009
Hi All,
I would like to uninstall CallManager 4.2. Does anyone has any step-by-step procedure on how to do this?
I have CallManager 4.2 running on a Windows 2000 server PC.
Regards.
Correct Answer by Jaime Valencia about 7 years 10 months ago
I would do as Brandon says and wipe it out, in any case all you need to do is go to add or remove programs and uninstall.
java
if this helps, please rate
Correct Answer by Brandon Buffin about 7 years 10 months ago
Are you installing another version of Callmanager, using the machine for another purpose or ? If you are repurposing the machine, simply wipe and reinstall.
Hope this helps.
Brandon
Overall Rating: 0 (2 ratings)
Correct Answer
Brandon Buffin Tue, 09/08/2009 - 10:07
  • Purple, 4500 points or more
Hope this helps.
Brandon
Correct Answer
Jaime Valencia Tue, 09/08/2009 - 11:10
  • Cisco Employee,
  • Hall of Fame,
    2011
java
