Problem forwarding port 25 to Mail server (through router & pix)
Sep 8th, 2009
I have a Mail Server behind Firewall. With an ipcop firewall connected and port 25 forwarded to the mail server ip, the exchange server works perfectly.
Now I have a combination of Cisco router and PIX. I cannot seem to be able to configure the pix and router to allow smtp traffic to the mail server. HELP!
Internet -->Cisco 3700 --> Pix 515E --> Mail Server
What do I do to get the router and the pix to forward port 25 to the Mail Server.
Detail - http://pivweb.net/fun/Network.jpg
Collin Clark Tue, 09/08/2009 - 10:46
  • Purple, 4500 points or more
Check the ACL on your PIX that is applied to the outside interface.
access-list OUT-IN permit tcp any host 10.10.11.80 eq smtp
It should be:
access-list OUT-IN permit tcp any host 201.13.12.102 eq smtp
You need to set the destination IP to the IP's located on the outside interface, not the private IPs.
Hope that helps.
prince.ibe Tue, 09/08/2009 - 11:53
Thanks. I have modified my config on both router & pix. And I see some improvement. I did a portqry on the mail server and I no longer get the NOT LISTENING message. I now get:-
TCP port 25 (smtp service): FILTERED.
I even turned fixup off on smtp 25. Still I can't get through. What else should I do?
Collin Clark Tue, 09/08/2009 - 11:55
Where are you seeing the message TCP port 25 (smtp service): FILTERED. ? The port scanner? What does the log in the PIX say?
prince.ibe Tue, 09/08/2009 - 12:16
The message is the response to my portqry on the mail server:-
portqry -n mail.gymnconference.org -e 25
The log does not show anything to on port 25 or the mail server..
XXXXXX# sh log
Syslog logging: enabled
Facility: 20
Timestamp logging: enabled
Standby logging: disabled
Console logging: disabled
Monitor logging: level debugging, 0 messages logged
Buffer logging: level notifications, 1326593 messages logged
Trap logging: disabled
History logging: disabled
Device ID: disabled
401004: Shunned packet: 100.100.101.98 ==> 109.9.248.67 on interface inside
Collin Clark Tue, 09/08/2009 - 12:18
Please change your buffer logging to debug-
logging buffer debug
Then try portqry again and post the log results.
prince.ibe Tue, 09/08/2009 - 12:37
I just copied some of the log:- 100.100.101.80 is the mail server
401004: Shunned packet: 100.100.101.98 ==> 59.47.169.9 on interface inside
710005: UDP request discarded from 100.100.101.80/137 to inside:100.255.255.255/netbios-ns
302014: Teardown TCP connection 1820309 for outside:217.14.83.102/25 to inside:100.100.101.80/1216 duration 0:02:01 bytes 0 SYN Timeout
connection 1820358 for outside:67.195.168.31/25 (67.195.168.31/25) to inside:100.100.101.80/1407 (192.168.8.253/1407)
Collin Clark Tue, 09/08/2009 - 12:41
Message 302014 shows that a connection is being built, so that's good. It does show 0 bytes though. Everything is working on the mail server right? Can you telnet to port 25 from the local LAN?
prince.ibe Tue, 09/08/2009 - 12:45
telnet 100.100.101.80 25 gives:-
220 mail.gymconference.org Microsoft ESMTP MAIL Service, Version: 6.0.3790.0 ready at Tue, 8 Sep 2009 21:44:03 +0100
helo
250 mail.gymconference.org Hello [100.100.100.11]
ehlo
250-mail.gymconference.org Hello [100.100.100.11]
250-TURN
250-SIZE
250-ETRN
250-PIPELINING
250-DSN
250-ENHANCEDSTATUSCODES
250-8bitmime
250-BINARYMIME
250-CHUNKING
250-VRFY
250-X-LINK2STATE
250-XEXCH50
250 OK
quit
221 2.0.0 mail.gymconference.org Service closing transmission channel
Collin Clark Tue, 09/08/2009 - 12:52
You mail server goes out this PIX to get to the outside correct? Typically when you see a connection and 0 bytes, the mail server can't respond. It's usually a service has stopped, asymmetric routing, etc.
prince.ibe Tue, 09/08/2009 - 13:10
So what do I do to solve the problem? I have even turned off fixup on smtp
Collin Clark Tue, 09/08/2009 - 13:15
You can enable packet capture on the PIX and make sure the packets come back. Do you have other routes out?
prince.ibe Tue, 09/08/2009 - 13:22
Nope. The route is just through the Cisco 3700 router out. I need to be sure which device is blocking/dropping the traffic. How can I test if port 25 is allowed on the router?
Collin Clark Tue, 09/08/2009 - 13:24
Create an ACL logging SMTP-
access-list 101 permit tcp any any eq 25 log
access-list 101 permit ip any any
Then apply to your interfaces. Make sure your logging is set appropriately too. Once you test with your port scanner, you should hit counts on the ACL and a message in the log.
prince.ibe Tue, 09/08/2009 - 13:48
From the hit count, there does not seem to be any activity through the smtp.
access-list out-in line 1 permit tcp any host 217.14.83.102 eq smtp (hitcnt=0)
access-list 101; 2 elements
access-list 101 line 1 permit tcp any any eq smtp log 6 interval 300 (hitcnt=0)
access-list 101 line 2 permit ip any any (hitcnt=14)
prince.ibe Wed, 09/09/2009 - 04:10
I did some tweaking on the config used nmap to test the ports. Result now shows that port 25 is open but I still get FILTERED from portqry on the mail server.
Result of nmap on the pix interface:-
PORT STATE SERVICE VERSION
23/tcp open telnet Cisco telnetd (IOS 6.X)
25/tcp open tcpwrapped
80/tcp open tcpwrapped
81/tcp open tcpwrapped
110/tcp open tcpwrapped
Result of nmap on the router interface:-
23/tcp open telnet Cisco IOS telnetd
80/tcp open http Cisco IOS administrative httpd
Command used: nmap -sT -sV -p 1-120 -v -PN x.x.x.x
What does tcpwrapped mean?
