SUP Sync
Sep 8th, 2009
I have the switch running with single SUP And the 2nd SUP is faulty. I got a new SUP from CISCO. However, the new SUP is having different ISO as compare to the existing SUP. Now I want sync the configuration & configure SUP as backup to other. Please advice me how to go forward.
Thanks!!
jbrenesj Tue, 09/08/2009 - 13:40
  • Silver, 250 points or more
What is the platform, 6500 or 4500?
what is the file system of the active sup, bootflash:, disk0: or bootdisk:
You can do a dir slavebootflash: for example to confirm you have access to the standby sup and then you can copy the IOS from the active to the standby, do a write mem and reload the standby sup to it loads the same IOS as the active + the config file
arun.patro Tue, 09/08/2009 - 14:00
It's 6500 & having CATOS.
I tried to access slavebootflash:, but no luck
Switch> (enable) dir slavebootflash:
Open device slavebootflash failed (unknown device)
Switch> (enable)
Also, fyi pls
Mod Hw Fw Sw
1 3.2 5.3(1) 5.4(4)
15 1.1 12.1(8b)E7 12.1(8b)E7
2 7.0 5.3(1) 6.4(9)
16 1.1 12.1(8b)E1 12.1(8b)E15
SUP in slot is the one I got from Cisco in RMA. They are having different Hw, Fw, Sw versions.
Pls advice. Thanks!!
