Reset show dsl int CRC error counters
Sep 8th, 2009
Is there some way to reset the count of CRC errors, header errors, etc. on an ADSL WIC? We have a couple of devices that were plugged into an ADSL connection with faulty cabling and the counters skyrocketed (into the tens of millions), making it very hard to monitor actual numbers now.
Even after upgrading the IOS, updating the DSL firmware and using clear counters on the interface, the counters aren't reset. Any ideas?
Giuseppe Larosa Tue, 09/08/2009 - 23:49
  • Hall of Fame,
    Founding Member
Hello Edward,
this looks like a software bug, at least after a reload the counters should be cleared.
Hope to help
Giuseppe
