09-08-2009 07:44 PM
I posted this on whirlpool but was just chasing some confirmation.
I am looking at the above hardware and I want to power 11 Cisco SLM2005 5 Port switches. The documentation says that it can supply 12 POE ports at 7.5w, now the question is is 7.5w enough to power a SLM2005?
I have looked through cisco's website and it doesn't state the power requirements. The closest information I get is from the User Guide which states that it supports IEEE 802.3af but that allows 1-12w.
Does anyone have any experience in setting up the SLM224P and using POE.
Cheers
Dale
Solved! Go to Solution.
09-09-2009 06:59 AM
Hi Dale,
I plugged an SLM2005 into an SGE2010P. It showed a draw of 3100-3300 miliwatts. This fits within class 1, 0.44 - 3.84 watts. 11*3.84=42.24. The SLM224P will meet your needs. The left half of this switch is PSE as indicated on page seven of the Admin Guide.
Hope this helps,
Christopher
09-09-2009 06:59 AM
Hi Dale,
Hope this helps,
Christopher
09-09-2009 06:01 PM
Thanks very much for your response.
Nothing beats being able to get the equipment, plug it and test it.
