09-08-2009 09:10 PM - edited 03-10-2019 04:40 PM
HI
I have rebuilt the Tacac server for cisco secure ACS v3.0 and then retore all the data via the "data restore" under the system configuration.
After rebuilt, it was only working for one day... and then it fails to authenticate users. I checked the event viewer, the error message is:
ODBC authentication dll failed to initalise, code -1110
and
CSMon message: Problem Logging on to CSTacacs. Got as far as Starting Processing in Auth module
any idea?
09-09-2009 11:29 AM
You could be hitting DDTS CSCdu52690.
I will suggest to do an upgrade ACS version 3.0 is old and unsupported.
09-10-2009 10:32 PM
When I tried to view it, it says:
This bug is no longer available in Bug Toolkit. Click bug ID for details.
would you be able to provide more information for this bug please?
kind regards
Rachel
