HWIC-1FE and ios version compatibility on 2811
Sep 8th, 2009
I would like to ask if a cisco 2811 running on an ios
c2800nm-adventerprisek9-mz.124-25a.bin should be able to make an HWIC-1FE
card work? I am also not detecting the card on any show commands. Plus i am seeing that all the LEDs (FDX/COL,100 and LINK/ACT)
are lit steadily even though there is no cable attached to it, is it safe
to say that the card could be defective?
athrunzala Tue, 09/08/2009 - 23:25
it seems that i don't have access to the advisor tool, what about other feature set like the ipbase?
goulin Tue, 09/08/2009 - 23:42
Should be the same... hardware support is usually done by IOS revision, as opposed to IOS feature set (eg if 12.4(25) supports it, then it will be supported from IP Base to Advanced Enterprise Services).
Joseph W. Doherty Wed, 09/09/2009 - 04:11
". . . hardware support is usually done by IOS revision . . ."
Usually is correct. An example otherwise, was, on at least 2800s, needed "Plus" image to support some ATM interfaces.
ajaju Thu, 06/16/2011 - 21:04
The HWIC-1FE requires a minimum IOS of 12.4(20)T..
