Inbound Fax load balancing
Sep 9th, 2009
i have the following scenario:
1- one gateway (PRI Line interface)
2- two RightFax servers
i used a SIP protocol between the gateway and the two fax servers , my point is how to configure a dial-peers on a gateway to make an inbound balancing fax call between the two fax server, the following is the configuration for the gateway:
### connection to the Fax Server #####
dial-peer voice 200 voip
destination-pattern 9979..
voice-class codec 99
session protocol sipv2
session target ipv4:10.72.28.110
session transport udp
dtmf-relay h245-signal
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
#### Connection to the server Fax2 ####
dial-peer voice 201 voip
session target ipv4:10.72.28.111
fax rate 14400
what additional command needed to achieve load balancing?
Nicholas Matthews Wed, 09/09/2009 - 04:48
That's all you need.
You can use "show dialplan number " to see what dial peers will be used.
-nick
jawwalit Tue, 09/15/2009 - 23:06
thanks , yes its work
but i has some problem, that when i shutdown one of the fax server the gateway still send fax to it even its down,
do you have any explain for that
Nicholas Matthews Wed, 09/16/2009 - 04:53
It will try, and when it is unreachable, it will attempt to send to it.
You may want to look into Out of Dialog (OOD) options pings. This will allow you to monitor the health of a SIP endpoint and fall-back when something fails.
thanks,
nick
