Unity 7 - Platform Configuration
Answered Question
Sep 9th, 2009
I am using an MCS-7845-ESC4 purchased as a Unity bundle from Cisco. According to the install documentation this is a platform overlay 3 server.
Following the install document and booting with the platform configuration disk for the 7845-ECS4 the system was auto installed with the following partitions and volume labels:
VOLUME_1 C: 24GB
VOLUME_2 D: 112GB
VOLUME_3 E: 136GB
VOLUME_4 F: 273GB
The install document does not show the partitioning above and talks about C:, D: and E: drives only.
I want to install this server in the correct manner so that it is TAC supported and performs well however, either the documentation is wrong or the platform configuration disk is doing something incorrect.
Can anyone advise?
Correct Answer by rob.huffman about 7 years 4 months ago
Hi Yuko,
Here is the reference;
Locations for Files on a Platform Overlay 3 Server (Secondary Server with Exchange on the Secondary Only)
Disk Array Partition Files
First
C
•Operating system
•Pagefile
First
D
•Program files, including Cisco Unity, Exchange, and SQL Server 2000
•Cisco Unity trace logs
Second
E
•Exchange transaction logs
•SQL Server 2000 transaction logs
Third
F
•Exchange databases
•SQL Server 2000 databases
•Unity Message Repository (UMR)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/installation/guide/vmexfo/5xcuigvmefo020.html#wpxref87281
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Wed, 09/09/2009 - 05:29
Hi Yuko,
First
C
•Operating system
•Pagefile
First
D
Second
E
Third
F
•Exchange databases
Hope this helps!
Rob
amitkumarp Mon, 07/26/2010 - 00:31
Hi Rob,
Can you give me an example of Folders to be made. In my case we don't have Exchange Server.
We have MCS7845-I3-ECS1 server i.e. platform overlay 3. I am installing Miscrosoft SQL Server 2000. At the time of installation it is giving me 2 options for Destination Folders.
Program Files and Data Files. If I go according to the installation guide I have to select following folders, correct me if I'm wrong.
For Program Files: D:/Program Files/Microsoft SQL Server
For Data Files: E:/Program Files/Microsoft SQL Server
Thanking you in anticipation of your quick reply.
Amit.
