Multicast routing clearing not working
Sep 9th, 2009
I had a problem with multicast so I wanted to clear all the learned enteries in the mroute table. When I ran "clear ip mroute *" then looked at table again nothing had changed.
How can I tell if the clear command actually worked because looking at the entries it doesn't appear to have?
Dan
simontibbitts Wed, 09/09/2009 - 05:06
  • Silver, 250 points or more
Hello.
You should see this first timer restart which is shown after each (S,G) and (*,G), it is the uptime timer.
(1.1.1.1, 239.1.1.1), 00:00:00/
Simon
