09-09-2009 04:02 AM - edited 03-15-2019 07:41 PM
I have CME 7 configured at a site and have the following problem
When you place a call from an IPT handset it takes ages to forward the call out the ISDN BRI.
If i do a debug isdn q931 and dial an external number from the phone it takes around 6 seconds to register on the gateway.
does anyone know what the setting is to speed up this process?
thanks
Rod
Solved! Go to Solution.
09-09-2009 07:27 AM
Try changing the destination patterns on your dial-peers to something more specific. The "T" in the destination pattern signals the router to wait for the interdigit timeout before forwarding the call. In your dial-peers, change the destination patterns to something like the following:
dial-peer voice 1 pots
translation-profile outgoing nuvia
destination-pattern 9........ (each "." signifies a digit, so configure to match the amount of digits you are trying to forward)
incoming called-number .
direct-inward-dial
port 0/1/0
Hope that helped, if so please rate.
09-09-2009 04:26 AM
have you checked the interdigit timeout setting- may be default?
09-09-2009 05:03 AM
hi thanks for replying
in my voice ports i have the timeout interdigits set to 0
Do I need to specifiy it in another interface or ephone ?
Ta
rod
09-09-2009 06:08 AM
Thanks for your reply - i have included some config in relation to my problem.
Please let me know if you need all of the config attached.
Rod
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn calling-number .
isdn sending-complete
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
voice-port 0/1/0
input gain -3
output attenuation -3
echo-cancel coverage 24
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/1/1
input gain -3
compand-type a-law
cptone GB
bearer-cap Speech
destination-pattern 9T
direct-inward-dial
port 0/1/0
dial-peer voice 2 pots
direct-inward-dial
port 0/1/1
09-09-2009 07:27 AM
direct-inward-dial
port 0/1/0
09-09-2009 10:08 PM
Thanks for everyone's help.
The 9T destination pattern was the cause of my troubles.
Thanks again.
Rod
09-09-2009 05:03 AM
Without looking at your config, I would say that its safe to say that the router is waiting for the interdigit timeout before forwarding the call to the BRI. You may want to configure more explicit dial-peers as opposed to a generic dial-peer.
