RV082 VPN tunnel break
Sep 9th, 2009
Hi All,
One of our customers has problems with VPN tunnels on RV082. After setting up tunnel it works correctly for few hours and then breaks up.. Altough Keepalive and DPD are on, the tunnel cannot be established automatically. The router needs to be rebooted and then tunnel sets up without any problem. I've atatched .zip file with screens from configuration of tunnel and logs from the device, if anything else could help in recreating this please let me know we will try to provide it.
Software version is 1.3-98tm
We are using this routers in our company and have no problems with them in similar configuration, but older FW version 1.3.7. I also didn't manage to recreate customers issue in our lab. Has anyone  idea what can be cause of such operation?
Best Regards,
Lukasz
daviddun Wed, 09/09/2009 - 05:47
Good Morning,
I looked over your log and wanted to look at the other side of the tunnel. Can you please send snapshots of it?
What is the ISP info on both sides (Type, speed and etc).
There are a few unanswered questions that I need to have to give you a answer
Have a great day :)
lukasz_naumowicz Wed, 09/09/2009 - 07:41
ISPs are:
Localization/Speed/Type
Swiecie/ 2Mb/1024 /DSL
Warszawa  2Mb/1024 /DSL
Piotrkow / 2 Mb / FR
Wola bykowska / 2 Mb / FR
If it helps the status of the VPN tunnel is connected all the time, but after some time customer can;t send any data through the tunnel, even ICMP message to the remote localization doesn't pass. I've attached the details of tunnel configuration on the second side.
Thank you,
Lukasz
daviddun Wed, 09/09/2009 - 07:55
Try placing Router 2 in aggresive mode and see if that fixes the issue
Te-Kai Liu Wed, 09/09/2009 - 08:21
It's not a recommended practice to post your WAN IP address and pre-shared key of your VPN tunnel on the forum for security reason.
daviddun Tue, 09/15/2009 - 08:56
Good Morning,
Sounds like the ISP maybe having some connection problems.
I would setup a ticket with SBSC and make arrangements to troubleshoot with them.
HAve a great day :)
lukasz_naumowicz Thu, 10/01/2009 - 10:32
Thanks for all suggestions, it looks as David said that it was problem with ISP, from some time the connection seem to be stable.
Best Regards,
Lukasz
Related Content
