RA VPN Local Address Pool IP Assignment Issue
I have configured RA vpn for remote users in ASA 5520 with version 8.0(2). The vpn was working fine since yesterday but somehow it has started giving an error in the debug of the ISAKMP & IPSEC that its not able to provide an IP Address to the client from the local address pool thus failing to connect to the vpn. I am attaching the config and the ISAKMP/IPSEC debug for your reference. Kindly help.
Collin Clark Wed, 09/09/2009 - 06:42
  • Purple, 4500 points or more
Any chance you can create a pool with a full class C address space? I've noticed weird things when you VLSM the pool.
Collin Clark Wed, 09/09/2009 - 11:08
I am actually short of the subnets Can you explain this a little further? Also Cisco suggests using a subnet completely different than any assigned subnet. For example, your inside interface is in the 10 network. If you can you should use something from the 172.16 or 192.168 networks.
