Dyanmic crypto map
Sep 9th, 2009
I have a VPN that will connect using one of 3 public IP addresses, is it possibel to setup a VPN like this? Normally I setup VPN's with a peer having a single static IP not a pool of IP's?
whiteford Wed, 09/09/2009 - 23:21
Thanks Andrew,
I was thinking this must be a bit of a security risk allowing any IP, but I guess it isn't any different to the Cisco VPN client as the public IP for our user can be any IP really?
Also I just tried setting up a VPn via the wizard in the ASDM and it says 0.0.0.0 can't be used. Is this a CLI option only?
whiteford Thu, 09/10/2009 - 01:06
I think this is the only article related to my situation:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805733df.shtml
Normally to add a VPN to the ASA I would add something like this:
access-list outside_MYcryptomap_15 line 1 extended permit ip 0.0.0.0 0.0.0.0 172.18.1.0 255.255.255.0
crypto map outside_map 17 match address outside_MYcryptomap_1
crypto map outside_map 17 set pfs group5
crypto map outside_map 17 set security-association lifetime seconds 86400
crypto map outside_map 17 set peer 81.14.1.1
crypto map outside_map 17 set transform-set ESP-AES-256-SHA
tunnel-group 81.14.1.1 type ipsec-l2l
tunnel-group 81.14.1.1 general-attributes
default-group-policy My-L2L
tunnel-group 81.149.1.1 ipsec-attributes
pre-shared-key 123456789
isakmp keepalive threshold 10 retry 2
Possible to manipulate the above to be dynamic?
If you read the config, the dynamic L2L is:-
tunnel-group DefaultL2LGroup type ipsec-l2l
tunnel-group DefaultL2LGroup general-attributes
authentication-server-group none
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
no IP address - just a psk.
And a normal crypto map - but no IP.
HTH>
whiteford Thu, 09/10/2009 - 02:06
This is what I'm going to add to the ASA:
crypto ipsec transform-set dynset1 esp-AES 128 esp-sha-hmac
crypto dynamic-map cisco 1 set transform-set dynset1
crypto map dyn-map 20 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
Does it look ok to you?
whiteford Thu, 09/10/2009 - 02:15
Thanks for spending some of you time on this btw.
1) Sorry that was just an example psk (123456789) normally I use 10 chars leters,numbers, symbols, uppercase.
2) Where would I put this in my config example? I guess I would use "set pfs group5" somewhere and what about the timeout?
3) I will be setting the remote IP subnets so will will no, so I guess I can miss this out?
Sure - no problem
1) ;) I would for a "dyanamic" used something a little longer, the likely hood that someone would guess or capture it is low - but just to be sure 32 or 64 charactures.
2) crypto map <> set pfs group5
3) You can miss it out, or have it in - belt a braces approach!
HTH>
whiteford Thu, 09/10/2009 - 02:39
I will try this after lunch. My boss is worried it's insecure, but I said it's the same as VPN client really as we don't know their public IP to lock the tunnel down with, would you agree?
whiteford Thu, 09/10/2009 - 02:53
Can you check this (not sure if my maps are right) and see what you think before I add?
crypto dynamic-map aw-dyn-map 1 set transform-set dynset1
crypto map dyn-map 1 ipsec-isakmp dynamic aw-dyn-map
crypto map dyn-map 1 set pfs group 5
pre-shared-key <64 char key here>
whiteford Thu, 09/10/2009 - 04:47
Andrew,
The first problem I got was:
crypto map dyn-map 1 set pfs group5
WARNING: This map entry is linked to dynamic-map: aw-dyn-map.
This attribute will be inactive!
please help
whiteford Thu, 09/10/2009 - 06:13
Andrew,
Sorry I'm confused (does take much does it)
I simply tried to add:
crypto map dyn-map 1 ipsec-isakmp dynamic cisco
;) no issues
Here is the thing, you can only have ONE crypto map configured on ONE interface at any one time.
Soooooo if you already have a crypto map configured and attached to the outside interface - then you just amend it, giving your dynamic crypto map and higher sequence number; hope this clears it up.
If not - see an example of one of my crypto maps:-
crypto ipsec transform-set ESP-3DES-SHA1
crypto dynamic-map dyno-map 10 set transform-set ESP-3DES-SHA1
crypto map vpntunnel-outside 1 match address vpn1
crypto map vpntunnel-outside 1 set peer 1.1.1.1
crypto map vpntunnel-outside 1 set transform-set ESP-3DES-SHA1
crypto map vpntunnel-outside 26 match address vpn2
crypto map vpntunnel-outside 26 set peer 2.2.2.2
crypto map vpntunnel-outside 26 set transform-set ESP-3DES-SHA1
crypto map vpntunnel-outside 60 match address vpn3
crypto map vpntunnel-outside 60 set peer 3.3.3.3
crypto map vpntunnel-outside 60 set transform-set ESP-3DES-SHA1
crypto map vpntunnel-outside 65535 ipsec-isakmp dynamic dyno-map
crypto map vpntunnel-outside interface outside
HTH>
whiteford Thu, 09/10/2009 - 06:54
I think I do. All my VPN's went down, when I compared the config with last night, I soon realised I had to add back:
"crypto map outside_map interface outside"
so when I added
"crypto map dyn-map interface outside"
bang! They all went down
If I get it I must leave "crypto map outside_map interface outside" as it is?
based on my example in the previous post how should that look? That way it shoudl click for me.
Thanks again Andrew.
Well from your config - you already have config for dynamic maps, so just add the below and it should work ok:-
default-group-policy AW-L2L
pre-shared-key <>
HTH>
whiteford Fri, 09/11/2009 - 06:18
Thanks I take it I can call the "DefaultL2LGroup" anything?
Also to remove this if I have to I can just use:
no tunnel-group DefaultL2LGroup type ipsec-l2l
no tunnel-group DefaultL2LGroup general-attributes
no default-group-policy AW-L2L no
no pre-shared-key <>
whiteford Fri, 09/11/2009 - 06:56
I understand that part, I'm just not sure where you got "DefaultL2LGroup" from, whether it is a system default "word" itself or you made up this?
I was thinking of just copying you code into my ASA tomorrow (out of hours) and testing?
whiteford Fri, 09/11/2009 - 07:09
Great stuff!
I will try adding just those 4 lines tomorrow and let you know how it goes.
1.) The great thing now is (well tomorrow) I can setup VPN's without knowing the customers IP address. I guess as long as the pre-shared key, and the IKE and IPsec phases match then I should be ok? Although I will use the IP if they have knowledge of it.
2.) Is having a dynamic VPN quite common?
OK - cool
1) Yep - makes things a little easier
2) Yes - as most buisness ADSL prices are still quite high (in the UK at least) and bundling a static IP on top, increases the cost. I have seen a sharp increase in dynamic VPN's. It also makes bringing a new remote site on-line much easier....just pre-configure the pix/asa and send out!!
whiteford Fri, 09/11/2009 - 07:34
Nice.
If I decide to turn this dynamic feature off, how would I achieve this?
whiteford Fri, 09/11/2009 - 07:54
Thanks, sorry for the simple questions.
I'm only a CCNA, forced in to the ASA world. Hopefully some training soon.
whiteford Sat, 09/12/2009 - 02:36
Hi Andrw,
I have added what you suggested. Now I need to connect a remote VPN to my ASA.
I am going through the ASDM IPsec VPN wizard, but it asks me to put in a IP address of the remote peer which I don't have. Do I have to use the CLI only for this? If I use 0.0.0.0 it says not supported.
My remote network has the 64 character pre-shared key I create and is pointing to my ASA's outside IP.
IKE Encryption - AES
IKE Authentication - SHA 256
IKE DH - Group5
IKE Lifetiem - 86400
IPsec Encryption - AES
IPsec Authentication - SHA 256
IPsec DH - Group5
SA life time - 86400
whiteford Sat, 09/12/2009 - 02:58
So the END I guess would be my ASA as it has a static and the "tiger" would be this remote VPN, which is a non Cisco device - horrid GUI.
This is what I originally tried to add:
I beleive I will need to remove "crypto map dyn-map interface outside" as I already have a outside crypto map as mentioned before. Does it look ok?
whiteford Sat, 09/12/2009 - 03:46
OK, so I don't need the crypto map part?
My earlier config contains:
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-256-SHA ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
for debug I will use "degub crypto isakmp 254"
whiteford Sat, 09/12/2009 - 04:02
Ah the debug is now showing somehthing at last:
Sep 12 12:57:56 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, IKE MM Responder FSM error history (struct &0xd0c4bf70) , : MM_DONE, EV_ERROR-->MM_WAIT_MSG5, EV_PROB_AUTH_FAIL-->MM_WAIT_MSG5, EV_TIMEOUT-->MM_WAIT_MSG5, NullEvent-->MM_SND_MSG4, EV_CRYPTO_ACTIVE-->MM_SND_MSG4, EV_SND_MSG-->MM_SND_MSG4, EV_START_TMR-->MM_SND_MSG4, EV_RESEND_MSG
Sep 12 12:57:56 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, IKE SA MM:53bb3ccd terminating: flags 0x01000002, refcnt 0, tuncnt 0
Sep 12 12:57:56 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, sending delete/delete with reason message
Sep 12 12:57:56 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, constructing blank hash payload
Sep 12 12:57:56 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, constructing IKE delete payload
Sep 12 12:57:56 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, constructing qm hash payload
Sep 12 12:57:56 [IKEv1]: IP = 214.*.*.67, IKE_DECODE SENDING Message (msgid=73ff5505) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Sep 12 12:57:56 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Removing peer from peer table failed, no match!
Sep 12 12:57:56 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Error: Unable to remove PeerTblEntry
This remote site is on 172.181.11.0/24 and ned to get to my subnet behind the ASA on 192.168.91.0/24
whiteford Sat, 09/12/2009 - 04:54
Hmm phase 1 is complete now, this is my output:
Sep 12 13:29:15 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Received encrypted Oakley Main Mode packet with invalid payloads, MessID = 0
Sep 12 13:29:15 [IKEv1]: IP = 214.*.*.67, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + NOTIFY (11) + NONE (0) total length : 72
Sep 12 13:29:15 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, ERROR, had problems decrypting packet, probably due to mismatched pre-shared key. Aborting
Sep 12 13:29:15 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Duplicate Phase 1 packet detected. Retransmitting last packet.
Sep 12 13:29:15 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, P1 Retransmit msg dispatched to MM FSM
Sep 12 13:29:16 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Duplicate Phase 1 packet detected. Retransmitting last packet.
Sep 12 13:29:16 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, P1 Retransmit msg dispatched to MM FSM
Sep 12 13:29:16 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, IKE MM Responder FSM error history (struct &0xd0c4bf70) , : MM_DONE, EV_ERROR-->MM_WAIT_MSG5, EV_RESEND_MSG-->MM_WAIT_MSG5, NullEvent-->MM_SND_MSG4, EV_CRYPTO_ACTIVE-->MM_SND_MSG4, EV_SND_MSG-->MM_SND_MSG4, EV_START_TMR-->MM_SND_MSG4, EV_RESEND_MSG-->MM_WAIT_MSG5, EV_RESEND_MSG
Sep 12 13:29:16 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, IKE SA MM:d0eb2626 terminating: flags 0x01000002, refcnt 0, tuncnt 0
Sep 12 13:29:16 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, sending delete/delete with reason message
Sep 12 13:29:16 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, constructing blank hash payload
Sep 12 13:29:16 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, constructing IKE delete payload
Sep 12 13:29:16 [IKEv1 DEBUG]: Group = DefaultL2LGroup, IP = 214.*.*.67, constructing qm hash payload
Sep 12 13:29:16 [IKEv1]: IP = 214.*.*.67, IKE_DECODE SENDING Message (msgid=b5bcb867) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Sep 12 13:29:16 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Removing peer from peer table failed, no match!
Sep 12 13:29:16 [IKEv1]: Group = DefaultL2LGroup, IP = 214.*.*.67, Error: Unable to remove PeerTblEntry
Sep 12 13:29:16 [IKEv1]: IP = 214.*.*.67, Received encrypted packet with no matching SA, dropping
whiteford Mon, 09/14/2009 - 02:11
Hi Andrew,
It seemed what ever I added stopped VPN client users from access our network, could the changes I added of affected them in anyway?
I'm set the config back to thursdays now and all can connect.
whiteford Mon, 09/14/2009 - 05:54
Am I right in saying Cisco VPN client users are also dynamic connections?
Think I will need to read that link again as you suggested
I simply added:
This the config for users on the ASA which seemd to stop users logging on, they would get the logon screen on the VPN client and it would then go and try authenticate the user and fail:
pre-shared-key <64 char key>
tunnel-group DefaultRAGroup ipsec-attributes
isakmp ikev1-user-authentication (outside) none
tunnel-group corp_users type remote-access
tunnel-group corp_users general-attributes
address-pool CLIENT_VPN_POOL
authentication-server-group RADIUS
default-group-policy corp_users
tunnel-group corp_users ipsec-attributes
pre-shared-key
tunnel-group corp_users ppp-attributes
no authentication chap
no authentication ms-chap-v1
tunnel-group corp_admins type remote-access
tunnel-group corp_admins general-attributes
address-pool ADMIN_VPN_POOL
default-group-policy corp_admins
tunnel-group corp_admins ipsec-attributes
pre-shared-key
Maybe addeding those settings change the config for the remote users.
apdatasoft Mon, 09/14/2009 - 02:58
Whiteford can you tell me what encrytion would you use for dynamic VPN in phase1/2. So that i can build the configuration for you
Cheers
AP
whiteford Mon, 09/14/2009 - 05:28
Well I normally use AES/SHA 256.
Networks:
Remote: 172.18.1.0/24
Local:192.168.90.0/24
apdatasoft Mon, 09/14/2009 - 03:05
Hi Whitefor,
Could you tell me what encryption would you use for Phase1/2 Dynamic VPN, so that i can build the configuration for you,
Cheers
AP
I can understand that - but to some minds to rest.....even if the phase 1/2 encryption key was captured in a man in the middle attack, the hacker would need to decrypt it and use it.....in the time frame it takes for the session to establish - as anti replay is a major factor in IPSEC.
So this means the hacker needs to break an 128bit AES encrypted key, the last time I checked no computer exists on the planet earth that can compute or even brute force it in under 50 million years.
If you use PFS as I suggested, this means the ecnryption key is re-negotiated anyway so the same encryption key's are never used more thant the specific time period.
