Warning message
DHCP Problems
Sep 9th, 2009
Hi all,
I have a Catalyst 3560 with a 12.4 ipservices image, in which I configured DHCP server for a data vlan and a voice vlan. the configuration is:
ip dhcp pool <pool name>
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
Pool 1 is for data and pool 2 for voice
The interface config is
interface range FastEthernet0/1-24
switchport host
switchport access vlan 109
switchport voice vlan 209
mls qos trust dscp
The problem is when I connect a phone it gets an IP address from the data pool, not the voice pool.
What am I doing wrong or what is missing in the configuration?
hipohoneywell Wed, 09/09/2009 - 08:28
I changed the port to trunk and now is getting no Ip address at all
That is because the switch port is expecting a 802.1q tag in the ethernet frame.
Does your IP hardphone support 802.1q? You also need to tell the trunk port, what the native VLAN is, i.e which vlan should the switch place all un-tagged frames into.
I would suggest you find out what the SIP phones can do before you make config changes.
mahmoodmkl Wed, 09/09/2009 - 08:07
  • Gold, 750 points or more
I dnot see the pool for voice..?
Can u paste the config.
Mahmood
hipohoneywell Wed, 09/09/2009 - 08:11
ip dhcp pool 2
network 10.16.109.0 /24
default-router 10.16.109.1
mattwilsonuk Wed, 09/09/2009 - 08:19
option 176 ascii "TFTPSRVR=172.16.244.189,MCIPADD=172.16.104.11,MCPORT=1719,L2Q=1,L2QVLAN=109,L2QAUD,L2QSIG=3"
This option needs to be bound to your data vlan, your phone will then get this ip address and see that the L2QVLAN=109 is the voice vlan, it will release the IP address then collect a new one from the voice vlan.
This then needs to be added to the voice vlan pool
option 176 ascii "TFTPSRVR=172.16.244.189,MCIPADD=172.16.104.11,MCPORT=1719"
The other options are for the telephone controller.
The above syntax is for avaya
Cheers
Matt
mattwilsonuk Wed, 09/09/2009 - 09:57
try just....
option 176 ascii "L2QVLAN=109"
on the data vlan
see if this makes the phone release the ip from the data vlan and grab one form the voice vlan
What model of phone is it, do you have a controller for it?
or are you just connecting it to a remote sip provider?
The other options are to specify things like the firmware for the phone.
We use mitel which luckily uses cdp to determined its voice vlan ;-)
Matt
