fwsm 4.0.6 pcap
ippolito
Trying to find the pcap file for a capture on an fwsm v4.0.6. I set up my capture like this:
access-list capacl permit ip 192.168.0.0 255.255.0.0 any
capture cap access-list capacl interface inside packet-length 1520 buffer 4000000
I can see my capture if I do a "show capture cap", but I'm trying to get at the pcap file.
I tried this, but it came back with a 404 error:
https://[fwsm_ip]/admin/capture/cap/pcap
I'd be grateful for any help.
Mike
glad to hear.
Yes, in the command ref. for copy capture:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/command/reference/c4.html#wp1881485
The following example shows how to copy a capture from within a context in multiple context mode. You must specify the context name:
hostname/Context1# capture abc access-list test interface inside
hostname/Context1# changeto system
hostname# copy capture:Context1/abc tftp:171.68.11.129/tftpboot/abc.cap
I will have the multiple context syntax added to the capture command reference
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/command/reference/c1.html#wp1880831
Example listed in the above link is only for single context.
Kureli Sankar
Is this multiple context?
If so you need this syntax:
https://ip_address/capture/context_name/capture_name/pcap
That worked. Thank you VERY much -- it has been a frustrating experience trying to find that in the documentation. In fact, is it documented anywhere on Cisco's site?
Thanks again,
Mike
glad to hear.
Thank you, you've been very helpful!
