service mgcp command
Sep 9th, 2009
I just wanted to confirm that the service mgcp command in the pri-group timeslots command is automatically created when the command ccm-manager config is entered.
I had manually added and removed the service mgcp command on a e1 controller interface.
After do a no mgcp and mgcp, I could see the config download but the service mgcp command was never created.
Any comments appreciated.
Thank you.
Paul
Jaime Valencia Wed, 09/09/2009 - 09:02
  • Cisco Employee,
  • Hall of Fame,
    2011
No, it's not automatically added.
You can refer to MGCP config guides and even they might tell you to add ccm-manager config you need to add the service mgcp under controller manually.
java
if this helps, please rate
