ASA nat between interfaces
tholmes
Can someone please help me solve this weird problem?
when I ping from a device on DMZ2 192.168.100.1 to a device on DMZ1 192.168.12.112
the ASA thinks the reply is coming from the inside network and so doesn't translate the response!
I've had to sub-interface g0/2 as I'd run out of interfaces.
interface GigabitEthernet0/2
no nameif
security-level 50
no ip address
interface GigabitEthernet0/2.1
vlan 3
nameif dmz1
security-level 50
ip address 192.168.12.1 255.255.255.0
interface GigabitEthernet0/2.2
vlan 2
nameif dmz2
security-level 40
ip address 192.168.100.254 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list dmz1 extended permit icmp any any
access-list dmz2 extended permit ip any any
access-list dmz1_dmz2 extended permit ip 192.168.12.0 255.255.255.0 192.168.100.0 255.255.252.0
access-list dmz2_dmz1 extended permit ip 192.168.100.0 255.255.252.0 192.168.12.0 255.255.255.0
nat (dmz1) 0 access-list dmz1_dmz2
nat (dmz2) 0 access-list dmz2_dmz1
access-group dmz1 in interface dmz1
access-group dmz2 in interface dmz2
static (dmz,outside) XX.YYY.XXX.112 192.168.12.112 netmask 255.255.255.255
Stange though, if I ping the Public IP address is works, but I need to use the real IP address
Syslog = 305006 192.168.100.1 regular translation creation failed for icmp src inside:192.168.12.112 dst dmz2:192.168.100.1 (type 0, code 0)
This is a cutdown version, everything else works fine, devices on the Inside and both DMZs can get to the Internet ok
Any help or advice would be much appreciated
Regards Tony
acomiskey
Level 10
Level 10
no access-list dmz1_dmz2 extended permit ip 192.168.12.0 255.255.255.0 192.168.100.0 255.255.252.0
no access-list dmz2_dmz1 extended permit ip 192.168.100.0 255.255.252.0 192.168.12.0 255.255.255.0
no nat (dmz1) 0 access-list dmz1_dmz2
no nat (dmz2) 0 access-list dmz2_dmz1
static (dmz1,dmz2) 192.168.12.0 192.168.12.0 netmask 255.255.255.0
6 Replies 6
acomiskey
Level 10
Level 10
Hello, there Acomiskey
Thanks for the reply, I'll give it a go and let you know
Cheers Tony
I made those changes but no difference, the ASA still thinks the return packet is coming from the Inside and not the DMZ so it drops it.
Thanks anyhow
Cheers Tony
acomiskey
Level 10
Level 10
What does the rest of your interface
config look like?
Its pretty standard, I've used sub interfaces on another firewall recently, same code too, without problems
interface GigabitEthernet0/0
speed 1000
duplex full
nameif outside
security-level 0
ip address XXX.YYY.ZZZ.2 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 192.168.1.253 255.255.255.0
no nameif
security-level 50
no ip address
description *** Link for SQL Server VLAN 3 ***
vlan 3
nameif dmz1
security-level 50
description *** Link for VIP DMZ ***
vlan 2
nameif dmz2
security-level 50
I added a line to the inside ACL to allow 192.168.12.0 through to 192.168.100.0 just to see what happens, the FW then rejected the reply with the following syslog message.
Makes no sense
Cheers Tony
It makes sense now.
The end user has 2 NICs in his DMZ servers, 1 into the DMZ and the other into the Inside (not very secure!)
This means return traffic was coming in via the d/g which was pointing to the Inside interface.
Many thanks for your help and taking the time to make some suggestions
Much apprecaited
Tony
