Looking for an NMS tool
Sep 9th, 2009
  • Gold, 750 points or more
Is there any tool that can alert based on a user-defined percentage/number of access ports that have gone down over a specific timeperiod on each switch, relatively easily out-of-the-box (vis-a-vis requiring heavy consulting/pro service customization)?
Joe Clarke Wed, 09/09/2009 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The Embedded Event Manager could be made to do what you want. I'm not sure if that's too heavy-weight for you. Once the initial script is created, configuration could be done with EEM environment variables (i.e. the percentage, type of alerts, etc.).
yjdabear Wed, 09/09/2009 - 10:53
It never occurred to me to consider EEM. One potential hangup with usnig EEM for this purpose is the access switches are a mix of CatOS and IOS. Nonetheless, would it be feasible to fulfill the requirement(s) with EEM applet(s) or would TCL script be needed?
Joe Clarke Wed, 09/09/2009 - 13:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It would only be feasible to do this with EEM applets if your devices support EEM 3.0 (e.g. 12.4(22)T or higher). Else Tcl would be required.
