Have two sets of Public IP and can't access the internet
Sep 9th, 2009
I got two sets of public IP from my ISP, one /30 and /24. I have a 2811 router which is connect to the ISP cisco switch. On my router I have the /30 and and the next interface is the /24 which is connect to a switch. I can ping my ISP GW and DNS servers but I can't access the internet. Can anyone look at my config and tell me what I am missing.
EDGE-Router>en
EDGE-Router#show run
Building configuration...
Current configuration : 3335 bytes
version 12.4
service password-encryption
hostname EDGE-Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yourdomain.com
archive
log config
hidekeys
interface Loopback0
no ip address
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description LINK TO ISP
ip address 69.177.74.206 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description LINK TO ARTNET INTERNET SWITCH 23RD FLOOR
ip address 69.177.131.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 69.167.64.205
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list standard outside-nat-inside
permit 192.168.0.0 0.0.0.255 log
permit any log
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
password 7 002501120A5E1F540472
logging synchronous
login
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password 7 13240506050910782077
logging synchronous
login
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Jon Marshall Wed, 09/09/2009 - 11:53
Shane
This is a bit confusing. Your default route points to 69.167.64.205 which is the other end of the /30.
So what are you trying to achieve with the /24 ?
Jon
shanemcanuff Wed, 09/09/2009 - 12:09
With the /24 I want to connect any systems that is connected to the switch on that interface to access the internet or I can access it from the internet since the /24 I have are public IP
shanemcanuff Wed, 09/09/2009 - 12:12
69.167.64.205 sorry I mean 69.177.74.205 is the ISP gateway. from my router I can ping www.goolge.com but when I connect to the swicth which /24 is connected to I can ping up the the ISP gateway and DNS servers but can't access the internet.
Edison Ortiz Wed, 09/09/2009 - 12:16
Verify your ISP has a route back to your /24 subnet, if they don't - the internet won't know how to get back to you.
Your config is fine.
BTW, where are you implementing NAT in your network?
__
Edison.
shanemcanuff Wed, 09/09/2009 - 12:38
Edison, I was thinking to do NAT but since two set of IP's are public do I have to do NAT?
Jon Marshall Wed, 09/09/2009 - 12:45
Shane
No, you shouldn't have to.
As Edison says, your config looks good. Assuming you have the default-gateway etc. correct on your /24 subnet clients i would check with your ISP.
Have you ruled out DNS ie. have you pinged google's IP address rather than URL.
Jon
Edison Ortiz Wed, 09/09/2009 - 13:02
If every device internally is going to be on the public /24, you don't need NAT but I find it odd that you will use a public /24 for your internal network. What type of business environment is this? Hosting services?
BTW, I agree with Jon - try pinging an IP instead of name from the switch holding an IP from the /24 subnet. Try pinging 4.2.2.1
__
Edison.
Edison Ortiz Wed, 09/09/2009 - 12:14
Your default route is incorrect.
Based on the IP address on the WAN interface
it should be
ip route 0.0.0.0 0.0.0.0 69.177.74.205
shanemcanuff Wed, 09/09/2009 - 12:35
the ip route 0.0.0.0 0.0.0.0 69.167.64.205 was a error I typed. the ISP gateway is 69.177.74.205.
shanemcanuff Wed, 09/09/2009 - 13:31
Thanks a lot guy, I call my ISP and for some reason the engineer forget to route the /24 to me.
