Direct Dialing Re-direction
Answered Question
Sep 9th, 2009
Scenario:
Call Blast 1: Phones A,B,C
Call Blast 2: cellphone 1, cellphone2
Currently, under the incoming dial plan, i have the mainline number being directed to the call blast 1 group. However, i would like to switch it to call blast 2 group after 6pm in the evening. I was wondering if there was a command in the cli or some script to switch these call blast assignments after 6pm everyday?
I am already aware that the AA can be scheduled for work and business hrs, but the client is not keen on having his clients press a menu option as yet since he doesnt have a customized script in hand.
Any ideas?
Correct Answer by Steven Smith about 7 years 8 months ago
Do it like this.
ephone-dn  32  dual-line
number 750 no-reg both
label Dummy
description 750
name 750
call-forward all 701
call-forward night-service 702
Don't use night service bell.
Here is how I would do it.
The call originally goes to a dummy ephone-dn.  That DN is CFA to a blast group.  That DN is CF Night Service to the other group.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html#wp1106036
Hope that helps.
Overall Rating: 5 (2 ratings)
murtazashikarii Wed, 09/09/2009 - 13:45
Thanks Steven. That solution looks good. I will try it out and let you know
murtazashikarii Wed, 09/09/2009 - 14:55
Steven,
i set up this dummy ephone-dn 32:
label Dummy
description 750
name 750
night-service bell
and did the call forward all to the 1st Call Blast Grp (701). Tested it and worked!
Coming to the night service... i enabled the night service bell on that ephone-dn 32.
I have the 2nd Call Blast Grp (702) that needs to ring during the night service duration ... how do i enable that? do i need to enable night-service bell under the ephone-dn for the call blast grp 2 or how is this to be achieved?
Correct Answer
Steven Smith Wed, 09/09/2009 - 15:15
  • Gold, 750 points or more
Do it like this.
label Dummy
description 750
name 750
murtazashikarii Wed, 09/09/2009 - 15:59
when i enable the nightservice, for some reason, the extensions assigned on callblast grp 1(day) ring once and stop. do you know why this is?
Steven Smith Wed, 09/09/2009 - 16:05
You would need to post the config for that.  Go ahead and tell me how the call routing works and I will take a look.
murtazashikarii Wed, 09/09/2009 - 15:08
Or better, how can i assign the extensions (say a call blast group extension) on which the night service should be activated? i know how to enable a particular ephone for this, but how can i achieve this where the call blast extension kicks in during the night service?
