Can I use 'extended ping' to simulate client ping? basic ACL testing
Sep 9th, 2009
Imagine I am trying to test ACLs and validate whether a given IP
could communicate with a target server.
My goal in this case below is to ping target server= as if I was
a client IP=
Isn't possible to do this with extended ping? I don't understand why it does
not work. I am doing this from the layer 3 switch where routing takes place for the respective VLANs both server and clients are member of. Both servers and clients are connected to layer 2 switches which are connected to layer 3 3750 distribution switches.
Protocol [ip]:
% Unknown protocol - "", type "ping ?" for help
Protocol [ip]:
Target IP address:
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: <=== *** Not sure why it returns invalid source. This is actual IP from a client.
% Invalid source
Jon Marshall Wed, 09/09/2009 - 12:53
The source address or interface used in extended ping must belong to the actual router/switch you are running the ping on.
So unless is assigned to an interface on the switch it will report that it is not a valid address.
news2010a Wed, 09/09/2009 - 13:42
Darn. So I guess if I add a secondary IP address under the respective vlan interface, that could be a way to test it then.
Jon Marshall Wed, 09/09/2009 - 13:44
Know it sounds a bit obvious but why not just use the client.
Or alternatively add a temporary entry into your acl for the switch interface address that connects to and then test.
news2010a Wed, 09/09/2009 - 14:20
I would use the client, but in this particular case there is no one on site so I want to make sure it is accurate before we have people trying the solution.
Sure, instead of adding the secondary IP address, I can definitely use the existing IP on the SVI.
