NAC - virtual gateway vs. real gateway
Sep 9th, 2009
Hi All,
I don't have too much experience with NAC deployment. I want to go with L3 (because we have central site), OOB (for LAN) and IB (for wireless and VPN). but I don't know whether I should go with real gateway or virtual gateway. I know virtual gateway is easier than real gateway. but technically, which way is more popular and provide better security measures?
any suggestion would be very appreciated.
thanks
Alex
Faisal Sehbai Wed, 09/09/2009 - 17:47
  • Gold, 750 points or more
If your remote subnets are multiple hops away, RIP would be the option you should use. They both are equally popular, but for L3 subnets which are remote, RIP is the most often used design
