ACS 4.2 QUESTION
Sep 9th, 2009
we are working as Remote operations engineer.
During normal conditions when Priamary link is up, we get access to AAA server, when primary link fails we login to the devices
using via back up link using line passswords, config is pasted below
My questionsis when ever we are using back up link( when primary fail) it take long time to promt for user name and password,
can any one tells me how to redue the time for login
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login no_tacacs line
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
Adhitya
Vinay Sharma Wed, 09/09/2009 - 22:00
HI Adhitya,
Whenever the authentication process starts, device first tries to send the authentication request to tacacs+ server. Since the tacacs+ server is not avilable, the device tries it 3 times i.e. 5 seconds for each try. That is the reason thier is a delay in the prompt. ONce the 3rd try is done, the device fallback to other method.
The deadtime period begins as soon as the last server in the AAA
server group has been marked as down (unresponsive). A server is
marked as down when the max-attempts value is reached and AAA fails to
receive a response. When the deadtime period expires, the AAA server
group is active and all requests are submitted again to the AAA servers
in the AAA server group.
This means each server in the list should be tried before the group
is marked dead.
The failover is depending on 2 values ie : " Server timeout " and " Failback
retry value ".
Vinay
adhityakarthik Thu, 09/10/2009 - 19:20
Hi Vinay,
Thanks very much for the update.
I am L2 resource i am doing this project of bulding new acs server.
Could you please let me know how to configure server timeout or fallback retry value(Please share doc regd the same)
Can you please give ur email id
Thanks very much in advance for the help
Adhitya
Jatin Katyal Fri, 09/11/2009 - 05:39
Hi Adhitya,
Here are the commnands:
Enter the number of times the server searches the list of TACACS+ servers before stopping.
tacacs-server retransmit retries
Set the interval the server waits for a TACACS+ server host to reply.
tacacs-server timeout seconds
Set the number of login attempts that can be made on the line.
tacacs-server attempts count
For more info:
http://docstore.mik.ua/univercd/cc/td/doc/product/lan/c2900xl/29_35sa6/eescg/mascupf.htm#xtocid173290
Default timeout value is 5 sec
In order to calculate total delay before you are prompted for username/password; you would be require to run debugs on the device.
Debug aaa authentication
debug aaa authorization
debug tacacs
term mon
Also provide the output of the below listed command
sh run | in tacacs
JK
adhityakarthik Sun, 09/13/2009 - 21:35
Dear All,
Thanks very much to all for the valuble inputs.
Right now we are using ACS 3.1 and we are doing fresh instlaation to ACS 4.2
I am finding cisco documents bit diifficult to understand
can you please suggest me some good document for buliding new ACS 4.2 even if it is cisco
Adhitya
