Cisco 6509-E to 15454
Sep 9th, 2009
my topology is like this.
fazmibakar Wed, 09/09/2009 - 20:21
on 15454 i use ONS-SE-G2F-SX SFP. u mean on cat 6509 i need to use XENPAK/DWDM X2 to connect to my 15454?
what happen if the 6509 use the normal SFP?
Jerry Ye Wed, 09/09/2009 - 20:27
You initial question didn't specify anything, I thought you want to do DWDM OC192 between the 6500's.
Okay, I think you have the MUXPONDER card with the ONS-SE-G2F-SX optics. ONS-SE-G2F-SX is 850nm multimode. On the 6500, all you need is GLC-SX-MM if you are using the WS-X6724-SFP or WS-X6748-SFP line card.
fazmibakar Wed, 09/09/2009 - 20:30
yes.thats rite.on 6500 i use GLC-SX-MM. so do i need to configure something else to connect from Site A to Site B?
Jerry Ye Wed, 09/09/2009 - 20:32
Are you looking for L2 or L3 configuration on the 6500?
fazmibakar Wed, 09/09/2009 - 22:01
it should be L3 config on 6500. is it i need to configure DWDM MTU size to match the 6500 MTU size?
Jerry Ye Thu, 09/10/2009 - 04:53
MTU size on the 15454? The 15454 MUXPONDER is L1 to the C6500. The C6500 is only treating the MSTP as a piece of cable. The only thing you need to make sure is the SFP is configured for GE instead of FC.
